Wiring a new 2 gang socket | Page 2 | on ElectriciansForums
Discuss Wiring a new 2 gang socket in the DIY Electrical Advice area at ElectriciansForums.net
Wago connectors in the original back box to extend new cables to the new face plate if needed.
So, just to confirm, I should wire the new socket in as normal using just one of the earth ports for the existing earth cable. Then I should run a separate cable from the other earth port on the new socket back to the metal back box? And I can definitely ignore the earth port on the new plastic pattress box?
Correct.
personally, i'd not bother earthing the back box. it's enclosed and untouchable.
Because I'd rather not be charged ÂŁ50 to have 3 wires connected for me. Now that it has been explained to me it seems very simple.
So is connecting a gas fire....difference is you'll smell the gas before something goes wrong. Looking at the picture the installation is probably over 25 years old.
I guess each to their own, just make sure you isolate safely and pull test the conductors once connected. You would not believe the number of times I've taken a DIY socket of the wall and a conductor falls or has fallen out, meaning the installation may have been a fire hazard since installation. There's a lot more to it than just connecting of 3 wires.
Reply to Wiring a new 2 gang socket in the DIY Electrical Advice area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
An example of the long term race to the bottom of quality of work in our industry, IMHO.
