Wiring a remote light switch to a wall switch advice. | Page 3 | on ElectriciansForums
Discuss Wiring a remote light switch to a wall switch advice. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
ok, we all know neon testers and volt sticks are not reliable. We've all had volt sticks lighting up on "dead" cables. ideally he should use a proper test meter ( calibrated of course ) but as I said earlier, was trying to keep it simple. Off to bed now ( orders )
1. identify the "live " red with a neon driver ( power on ) . if you not got one, £1.50 from any DIY store And possibly blow your hand off
Why not call your local electrician and ask him how much it would be to change a light switch that way it will be done correctly and you wont risk endangering your self
Reply to Wiring a remote light switch to a wall switch advice. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks guys, I'm going for the safe option and take your advice in getting a qualified electrician to look at it. We've inherited these issues so...
Yes the neutrals will be connected together in the same terminal and the earth joined in a 2screw earth connector just behind the switch.
