wiring a ring in 2.5 is no longer acceptable? | Page 2 | on ElectriciansForums
Discuss wiring a ring in 2.5 is no longer acceptable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I too don't see a problem the cable only needs increased csa through the insulation not at the accessories so you could cut it back to 2.5:D
6mm for cookers / hobs will now have to be 10mm if they keep insisting on stuffing fibreglass in between floor joists because the builders won't pay the extra for other insulation material. Then imagine trying to get 16mm into shower switches.
Reply to wiring a ring in 2.5 is no longer acceptable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Hi and Welcome to the forum! Sounds like you keep yourself busy in your retirement!
