K
k_d_ch
I have some questions regarding wiring a Honewell CMT927 thermostat to the electric supply and the boiler. The boiler is plugged into a spur socket at the moment and as I understand, since no extra spur from a spur is allowed, the existing spur will have to be modified in order to connect the thermostat to it.
My first question is whether I understand it correctly that since the thermostat needs its own fuse (the wiring diagram supplied with the thermostat says "<5A", does it mean the only option is a 3A fuse?), and the fuse installed into the boiler plug at the moment is 13A, I need to change the existing socket for a 2-gang one where the boiler and the thermostat can be plugged in independently: the boiler as it is with its 13A fuse, and the thermostat with it own. Or perhaps there is a simpler solution?
Also, am I allowed to carry out this job as a DIY, non-registered, electrician?
I would greatly appreciate any advice.
