Guest viewing limit reached
Wrong unit then Spoon??
Looks like it's not a 'like for like' replacement mate.
Maybe the OP can confirm the data sheet i have posted is the unit he has.
The client said that the fan unit came on when the lights for each room came on then off when the lights were off. But it was faulty when I went to swap it over
Then the person who wired up the original fan wired the switches into the fan circuit.
Have you checked out the 5 core cable to see what its wired to?
Lol I am a Diyer but I have basic knowledge.
You said "the client". Which makes out you are getting payed for this, which raises the question of... Are you insured to do this work?
Have you found out what the 5 core cable is wired to?
The different speeds may mean the fan runs permanent on low speed and activation of the lighting in one of the rooms boosts it to a higher speed. You could then have a lower run over until it drops back to the low speed.
I am only assuming this is how it is connected. You need to find out exactly how the switching is connected, trial and error is not the best way forward.
London
Wiring advice for multi room extractor fan
John Dinneen,
AJshep,
