Wiring colours | on ElectriciansForums
Discuss Wiring colours in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
elektrisien
Say I am wiring a school. My blue cable is finished, but I still have a lot of brown cable. Can I use the brown iso blue for a ring circuit supplying socket outlets, I will now have 2 browns and 1 earth in the trunking. Is this acceptable or good practice ? I dont think so, but the electricians on my site are doing it.
BRB identificaton of conductors spring to mind I would say without even looking that you have two choices No and No
Chris
OK I was being lazy BRB 514.4.4 page 91 and table 51 on next page choices remain the same No and No
Hope taht helps
Chris
:eek: Where exactly is this school (so I can be sure that no-one in my family attends), whom is completing the EIC (because I wouldn't), and what 'outfit' are doing the wiring (so I can avoid them):eek:
Thanks, I was thinking it could not be right. As I am not employed by this company, I will keep my mouth shut. I only noticed when installing the CAT 6 cable on site. Better not to make problems for yourself.
Thanks, I was thinking it could not be right. As I am not employed by this company, I will keep my mouth shut. Better not to make problems for yourself.
No don't keep your mouth shut, ask your employer for a written instruction not to comply with B.S.7671 ( 2008 ) just so as to protect yourself
Buck passing like you have never seen it before will happen and you will end up carrying the can perhaps you should place a call to health and safety give a duff name if you dont want to be identified.
Chris
Yep stitch them up; lets face it anyone prepared to cut corners just because they have run out of one colour of single core will definitely have more serious and dangerous bodges elsewhere.:mad::mad:
Any spark worth his salt would refuse to undertake such dubious practice so even in these hard pressed times they should be stopping the installation until the correct materials were to hand.
Like I say, I am not working for this company. I am only doing the CAT6 cabling for another company. But as I am working towards becoming a electrician myself, I am always checking the wiring whenever I get the chance, too get a little bit more practical experience. To tell the truth I took this company's phone number, I want to phone them for a job. They are doing schools, hotels etc. Really big jobs, and everything electrical including fire alarms etc. It will be excellent experience. They will not employ me after I reported them to Health and Safety. I will check again tomorrow to make sure. Maybe they will pull all the blue cable tomorrow. They are probably just waiting for a delivery. The extra brown cable may be a draw cable ! Who knows?!
Reply to Wiring colours in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Apart from ripcord and maybe a speciality flat elevator type ribbon cable I've also never seen a cable with two identical blue wires. I highly...
Hi there, I have dismantled my DEFENDER POWER POD 3KVA 110V TRANSFORMER & upon re- connecting the wiring, there now appears to be 2 extra wires...
