As some of you know, I'm doing a first fix for family member. I now know that in a modern house its best to do loop method of wiring from switch to switch due to modern day down lighters and light fittings only accepting one cable. I did have a thought though (bear with me) as there are 3 x cupboards on the ground floor of using flush joint boxes in each one to wire the various light switches to etc. I would still loop each LED down lighter together though. so all j/boxes would be accessible for test inspection and maintenance. Anyone done similar? thanks
