Wiring for 2ph coffee brewer | Page 2 | on ElectriciansForums
Discuss Wiring for 2ph coffee brewer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The specific model in the OP is the E213263 which is the CE marked variant and according the the specification it requires two phases (of a UK TP supply), neutral and Earth.
[ElectriciansForums.net] Wiring for 2ph coffee brewer
It looks as though it actually needs a 240v supply, not 400v, so looking at the diagram on the right, you would connect live to L1 and neutral to L2, the American system appears to be L1 to N is 120v, L1 to L2 is 240v. That's why the neutral is crossed out. I don't think it needs a 2 phase supply at 400v. Anybody else think that too??
You can see from the data plate in the OP that it is clearly a 230V/400V model, not a US 120V model.
The diagram you are referring to is for the US model (and other countries), the clue is in it being for 120V and 208-240V connections when the data plate on the OPs machine shows that it is a 230/400V model.
Yeah I can see now the OP pic of label on box and the diagram are conflicting! I thought the OP put on the diagram after.
Reply to Wiring for 2ph coffee brewer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
