Wiring for New Electric Hob - 4 wires | Page 2 | on ElectriciansForums
Discuss Wiring for New Electric Hob - 4 wires in the UK Electrical Forum area at ElectriciansForums.net
London
Brought a new hob Russell Hobbs (RH60EH402B) because the old one was cracked. New one seems to have four wires, but the old one only had 3. I think I need to pull out the oven to get access to the box that the wires feed into. Do you think I will I be able to connect the new hobs wires easily into this box?
I tried removing the oven today and I could not find the connection point/box for the wires.I think it is behind a cupboard which I cannot seem to get access to without cutting/breaking part of the cupboard.
I think I managed to break the oven as it now turns on but there is no heat so well done to me for that. Fortunately it is really old and several things were already not working with it so was about to replace it anyway, just seems weird that it broke so easily I was very gentle with it.
Is there any safe way of connecting the old wire into the hob so all the rings work? If not, any clues as to how I can get access to the connection box without pulling my kitchen apart?
Picture of Old cable :
old hob cable.png - https://drive.google.com/open?id=1D3DTbCSAzJ9AJqUCllMYYA1vd9LqYqRf
Picture of new cable
new hob cable.jpg - https://drive.google.com/open?id=1I4H3YxhdaaW_FJ-6WM9KDcnSROWkdBdP
Thank you.
I found the connection box/switch the old 3 wire cable for the hob is connected into :
[ElectriciansForums.net] Wiring for New Electric Hob - 4 wires
The front panel switch was loose so I brought a new one (cooker control 45 AMP double pole switch with mains socket) I have wired up the new 4 wire cable into this, no mains connection yet, just did this so I could take a picture of how I think it should be wired so some one could confirm it's correct. You can see the two live cables black and brown/red fed into the L load port on the socket, I think this is what was suggested, does this look ok? :
So...you have managed to connect the hob once and only two rings worked .....you have completely broken the oven which you said that BITS were not working anyway and now the front of the oven switch was loose and needed a new one........WHEN WILL YOU REALISE YOU NEED A SPARKY......WHEN YOU HEAR A BANG?....OR WORSE
guess that as you have done it is almost right. with the connections as you have said,link L1 to L2, then try that. sounds like L1 feeds 2 rings and L2 feeds the other 2.
I’ve got exactly the same with a new ceramic hob. With red to L2, Black yo N and earth to earth it leaves me with an L1 with no cable in. Advice elsewhere seems to be put a horseshoe connector / link cable between L1 and L2. Does that make sense?
After spending half a day making the hole bigger in the worktop for the new hob, the thought of unscrewing the oven as well and messing around with that was not appealing. So I thought I would try connecting the old wire that I had disconnected from the old hob into the new hob (silly me)
Switched off the electricity for the whole house,
The new hob has four ports for the wires, Earth, L1, L2 and N.
Connected earth/blue/yellow cable into earth socket, brown into L2 and blue into N as per instruction manual. Manual showed black going into L1 but of course this was the old cable so that one was missing.
Probably not a great idea I know. Anyway the hob powered on, but I could only get heat from the two front rings heated up.
Have I damaged the hob? Would wiring it up properly really be that difficult?
No it’s not damaged there’s no live feed to the rest of the hob it depends on cable size into the box and total power rating of the hob
Reply to Wiring for New Electric Hob - 4 wires in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
In all likelehood, no different. The RCD on the left is looking for electricity that is going missing in action. If the total missing reached...
