thedawnbefore
Hi, I'd be grateful for some pro. advice on the best cable choice and termination throughout a domestic greenhouse.
The building is relatively large at about 100sqft and will naturally be a permanently hot, wet, 100% humidity and UV-intense environment. The building will have an IP56-rated consumer unit professionally installed inside.
From there I was thinking:
Any advice sincerely appreciated. Many thanks.
- 5ft IP56 non-corrosive LED batten & switch
- x2 1 gang IP65 sockets at each end (one powering a 2kw heater for long periods of time)
- x1 2 gang socket on the exterior
