wiring Kitchen appliances. | Page 2 | on ElectriciansForums
Discuss wiring Kitchen appliances. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, A builder friend of mine asked me if all large kitchen appliances ( ie dishwasher , fridge ect ) have to be run off a fused switch spur. He said an electrician he has used insisted that he cut the plugs off the new appliances and wire them in directly to the fused switch. I told him I dont belive this is the case but then started doubting myself as Im new to the electrical trade. Has anyone got an answer for me. Sorry if Im being dim and should know this is the case.
Thanks.
What is wrong, IMHO, are the numpties who don't put accessible switching, being a FCU or DP switch, above the worktop for devices such as washing machines, and large fridge freezers so when "old" Mrs Smith has a problem you have to turn yourself into a removal man to unplug devices!
Let's be brutally honest here....
Firstly, most customers want the ability to pull an appliance out and disconnect it without needing to get an electrician out, especially with modern appliances lasting only 5 years. Additionally, during that time they will probably have a service engineer out a few times who needs to get it into the middle of the kitchen floor to work on it. I respect that and always install a nearby socket switched from above.
Secondly, I have never ever found that having a fuse in an SFCU as well as having one in the plug of an appliance has caused me or any customer problems due to no discrimination. In the unlikely event that an appliance does blow a fuse, it's not exactly hard work to check which one it is.
This topic is being way "over-thought"
Reply to wiring Kitchen appliances. in the UK Electrical Forum area at ElectriciansForums.net
As an aside. I have seen patress/sockets fitted upside down under kitchen units with an appliance plugged in. The sockets were firm and not moving...
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
