Currently reading:
Wiring LED's into existing vehicle light harness on each side
Discuss Wiring LED's into existing vehicle light harness on each side in the Auto Electrician Forum area at ElectriciansForums.net
Hello All!
New to forums and not to bright so bear with me. I would like to wire an LED light into the Headlight/parking light/turn signal wiring harness on a 2018 F150 (just a sample vehicle).
MY LED has two power wires and one ground wire.
I would like MY LED to work as a marker light AND blink with the turn signal when turn signal is activated.
If I connected one of MY LED power wires to marker light power wire on vehicle and the other LED power wire to turn signal power wire on vehicle and ground wire to ground on vehicle would this work?
I have attached a very crude drawing....no laughing
Thanks in advance!
  • LED.pdf
Reply to Wiring LED's into existing vehicle light harness on each side in the Auto Electrician Forum area at ElectriciansForums.net
