Wiring Lighting Circuits more than 2x 2 ways and intermediate | Page 3 | on ElectriciansForums
Discuss Wiring Lighting Circuits more than 2x 2 ways and intermediate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
use twin and earth between all switches as the strappers,connect a live feed to the common of one of the 2 way switches and connect your switch wire to the common of the other two way switch.
hi i arrived at a job with an intermediate lighting circuit, im having problems with wiring the circuit as the previous electrician ran the switch live to the intermediate switch where obviously the two three core cables are, the circuit has also 2 two way switches any help would be great thanks in advance..
it isnt a problem , you can wire the switch wire in at any switch just connect the switch wire as you would with a 2 way.Doe's this help or have i read your question wrong
i did do that having trouble switching the other two way switches as in switching on/off the circuit??? thanks ill try it again tomorrow cant wait, i was in a rush that evening cheers for reply
make sure that all the switches have the same colour connductor in L1 and L2 ( strappers) and make sure that you havent put a cable from one three core on one side of the intermediate and one on the otherside of the intermediate.I know it might sound obvious but it's easy to do,ive done it.
Reply to Wiring Lighting Circuits more than 2x 2 ways and intermediate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
How has this been wired, do you have the supply at one two way and the cable to the light at the other two way with cables from the intermediate...
Thanks for your feedback. Its reassuring to know your experience suggests space won't be an issue. I requested 47mm backboxes for switches when...
