Wiring newer Lutron style 3-way light switch | on ElectriciansForums
Discuss Wiring newer Lutron style 3-way light switch in the UK Electrical Forum area at ElectriciansForums.net
Mississauga, Canada
Hi guys
I'd like to switch out the old rocker light switches with Lutron style.
The 3-way ones have terminals X, Y, Z in the picture all on one side.
The Newer style has two on the right, one on the left, A, B, C (ignoring the earth).
Could any kind person please tell me the map from X, Y, Z to A, B, C, please?
Thanks in advance
Will
  • [ElectriciansForums.net] Wiring newer Lutron style 3-way light switch
Difficult to say to be honest. @Megawatt who is a US member may know for definite when he sees this. This is pure speculation but I am guessing the middle screw is common just because the screw is a slightly different colour.
Hi guys
Thanks in advance
Will
Will put your hot wire on the left by itself which would be A then put Y to the first screw on the top right which is B and put Z to the bottom right screw. Good luck
Reply to Wiring newer Lutron style 3-way light switch in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Thanks again for your help, now solved đź‘Ť
