Wiring of 5A lighting sockets | Page 3 | on ElectriciansForums
Discuss Wiring of 5A lighting sockets in the Lighting Forum area at ElectriciansForums.net
For lighting effects I use smart lamps. I have one in a living room lamp for when we watch movies etc and the other under a dresser in the kitchen for mood lighting if we have a posh meal etc.
Also handy for when we're away as we can set the lights to come on and off at random times to give more of an impression that we're in.
Only downside is we need a phone or tablet at hand to control the lighting.
Hi Kuffs,
It's probably best to say if you are an electrician or DIY. If you mention that you are DIY then you may/will probably get some advice rather than the comments above. However, I personally don't give out DIY advice as I see it causing more harm than good in the long run, so my advice when a question like this is asked is to always get an electrician in.
Kuffs.....I like what you say as far as letting people know you are not a qualified sparky. I'm not qualified but have worked as a mate since I retired and have always been interested in domestic stuff. In my experience in the forum, if you are honest and know your limitations you won't get too much abuse.
Hi Kuffs,
Reply to Wiring of 5A lighting sockets in the Lighting Forum area at ElectriciansForums.net
If the OP could DM you with that info? Rough area is fine, but don’t post your full address in public, obviously.
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
