Wiring regs Germany | on ElectriciansForums
Discuss Wiring regs Germany in the UK Electrical Forum area at ElectriciansForums.net
E
evo457
Would anyone happen to know where I could get my hands on a copy of wiring regulations for Ger many? I recently moved over and am renting a house , which in my opinion, would probably fall foul of many of these regulations. Need some ammo before I confront landlady, to get it sorted!
Give us some examples of these faults you think are falling foul of VDE/DIN 100
where to start,
Not had proper look yet, tester in one of many packing boxes,
· outdoor skt, no RCD protection
· All visible JB's in cellar damaged, would notpass IPX2
· visible, in damaged JB's:- cpc's not connected.
· no cpc's light fittings
· Lots of DIY cpc's + n fitted together in chokyblocks.
Could go on, but too drunk @ mo
Thanks for hint, as to where I can get regs from, will looktomorrow.
Will also post some photos of CU , dose not comply with 17thedition!
[h=2]Your Message[/h]
Read more: http://www.electriciansforums.net/newreply.php?do=postreply&t=75123#ixzz2PiPcQQnG
OK,
- Ootdoor installations without RCD are allowed, when they are old enough.
- Damages which expose wireing are not allowed. Non connected cpc's are also possible, if you have a old TNC-S indstallation, whichw as extended during the years. Then it is required _not_ to connect the cpc's unless eveything behind is a TNS- Installation.
-chokyblocks are also valid in a old installation - there was nothing else 40 years or more ago
- löights usually have no cpc in many installations of older buildings.
From which Year is your building?
Reply to Wiring regs Germany in the UK Electrical Forum area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
Take your photo on phone. Screenshot it to replicate it, then crop out the excess screen. Brings the image file down to a reasonable size. Was...
