Which ever couple fits the run is so small I'm not fussedJust to clarify, are you intending to use plastic or metal conduit?
Discuss Wiska box with earth gland and conduit? in the DIY Electrical Advice area at ElectriciansForums.net
Threaded galv conduit will screw straight in to the earth gland without need of a coupler.Which ever couple fits the run is so small I'm not fussed
The brass plate is not threaded. You do not open the hole in the Wiska box you use the thread and then use the grub screw on the plate to fasten the gland.Threaded galv conduit will screw straight in to the earth gland without need of a coupler.
If you do want to use a coupler, then you would need either a long brass bush or a nipple coupler and female coupler.
With plastic, a male adapter should have a thread long enough to reach the earth gland, you may have to enlarge the hole in the whiska box.
Is your mate an electrician then?Cheers all for your help and for all those concerned yes It will be notified work and signed off. My mate does it for the council.
No he's in taxidermyIs your mate an electrician then?
I'm not doubting your obvious talents Mate, you are obviously well versed in wiring up aircraft, question is, can you honestly say, your service qualifications, relate to the rules and regulations regarding domestic installations, you may think so but it's very doubtful, imo, I really don't mean to be savage, domestic electrics, may be know where near the skill set of an Aircraft Tech, but there are rules to follow. Your insurance company may have something to say on this issue Mate. I wish you luck and hope you get the desired results you want.What figures?
Put it this way if I can wire a 9 million pound aircraft avionics suite and air defence system. I'm sure I can manage a 10m swa line. And as I'll be notifying my local authority to get them to sign it off what really does figure?? Anyway it's my house and my insurance policy and some kind people have answered my quiry so... go figure.
Think I had better sign off on this one, for fear of saying something, perhaps I shouldn't.So you have your 17th, well you can navigate a book then.
Yea I've also read all the Harry potter books on my own tooSo you have your 17th, well you can navigate a book then.
Maybe you should have signed off before you started. The generous blokes/ladies already assisted with my query before you started piping up. So you were zero help anywayThink I had better sign off on this one, for fear of saying something, perhaps I shouldn't.
Reply to Wiska box with earth gland and conduit? in the DIY Electrical Advice area at ElectriciansForums.net
