I've just used one of the Wiska ones (8 x 2.5mm max cca circuits + 2 x 10mm max cca circuits) and whilst I suspect Dave's statement about the cost is totally correct, they aren't too bad. Suited the job I was doing (quite space restricted).
Inside they are a little tight, would be better if there weren't so many plastic protrusions within the space (such as the cover mounting screw pillars) and if the plastic DIN rail was in the middle of the box and not so offset. The Wago terminals could do with better fixings on the ends of the rails and whilst I'm a big Wago fan, I'm not that impressed with the terminals in these and their ability to stay on the rail when placed load by the cables connecting to them. Would be nice as well if it actually had 4 cover screws to make use of all four cover screwholes (think this is a packaging error but irritating none the less).
But, in the right circumstances I'd use one again. Saw them in a local wholesaler a couple of weeks ago and had cause to use one last week. I've used the DIY approach a couple of times and I can totally see the appeal of both approaches.
So, in short... I think they are good in the right circumstances but they aren't going to be an item I keep on hand mainly due to the cost.
