as title. see photo. wet-pants had a diagram showing the exact position of my downlights.so where does he run his wet works? had to reposition all 4 lights. the cables in the pic are in the alternative hole. lucky i didn't drill his pipe.
Discuss wonder why we bother sometimes in the UK Electrical Forum area at ElectriciansForums.net
lucky? if i was you id have carried on to prove a point.as title. see photo. wet-pants had a diagram showing the exact position of my downlights.so where does he run his wet works? had to reposition all 4 lights. the cables in the pic are in the alternative hole. lucky i didn't drill his pipe.
it's the same. because the photo was taken at an angle with a wide angle lens ( on phone), perspective is distorted. you see this often with verticals converging.it might be an optical illusion but in first pic where there are 2 holes second hole which is new position looks different dia to me .
Reply to wonder why we bother sometimes in the UK Electrical Forum area at ElectriciansForums.net
