Worcester Bosch Greenstar Regular Boiler - Always ON plumbing advice | on ElectriciansForums
  • Thread starter Pgeddon
  • Start date
  • Replies 0
  • Views 177
Discuss Worcester Bosch Greenstar Regular Boiler - Always ON plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Worcester Bosch Greenstar Regular Boiler - Always ON Morning all,
I've noticed very recently that our Worcester Bosch Boiler is constantly ON and making a fair bit of noise.
The flame is not on, but certainly sounds like the pump is running, AND the water temperature does seem high considering we've not had any demand for it for a good 48hrs or so. Boiler is a 40cdi Greenstar Regular, Setup CH only and an unvented cylinder.
I recorded a video to help describe what i'm seeing/hearing, that can be found HERE
My questions are
:-is this easy to fix?
:-if not, is it expensive to leave it like this till i get an engineer out? (ironically i think this started happening after it's last service a couple weeks back!.. so hoping it's just a setting they've wrongly activated)
thanks for your help all,
Ged
Worcester Bosch Greenstar Regular Boiler - Always ON to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Worcester Bosch Greenstar Regular Boiler - Always ON plumbing advice in the Plumbers Forums area at ElectriciansForums.net
H
Worcester greenstar combi problem Hi this is my first post so please be gentle. I have a Worcester greenstar 28i junior combi fitted in my house...
Happyharry
H
Vent valve greenstar 35cdi compact how to get back inside Hi Took the vent valve off which has a spring clip and sits in the top right hand side...
diy_massacre
Boiler sounds like a plane Can anyone advise why my Worcester Bosch System boiler when heating hot water does this sort of surging/woosh/hum...
simbiant
W-plan pump run on Son recently moved into a 20 year old house with what appears to be a W-plan system using, I think a Worcester Bosch Greenstar...
davidwf
B
Boiler problem I have a condensing boiler in my kitchen and every time I pour waste water down the sink there’s a gurgling noise at the boiler. I...
Belxvs
B
