This message is only to try and prevent other Readers from getting misled / confused about the Pump Over-run:
The Pump Over-run is ONLY Controlled by the Boiler - when the Heat is dissipated from the Heat Exchanger the Pump Over-run is turned Off.
That is the ONLY way that the Pump Over-run can be Operated - I think that this process is controlled by Thermistors within the Boiler.
I am NOT any kind of Expert in Electrical Wiring / Installation - BUT - I know that the Pump MUST be wired to dedicated Terminals within the Boiler - identified in the Installation Instructions.
I do NOT know whether a Different / incorrect configuration of Wiring can cause the Pump Over-run to operate `Correctly` - but I very much doubt it.
