Hi all , hopefully somebody on here can help me out, I recently went to change a led unit in a workshop , cut power ,changed led unit , then when I switch power back on it didn't work and also took the bank of 5 lights down with it , disconnected it and the bank still doesn't work, checked fuse , all ok , checked switch ,(retractable switch) power is their . Still No power at all 5 lights , at some point they have been on sensors as they is 1 highbay sensor on each bank (6 banks)
Any thoughts and help would be greatfully appreciated
Thx Shane
Its my place of work , yes I am a trainee,
Also would a contactor be on every bank , ones I've seen don't have reset switches on , I've tried listening for a click when I press switch but don't hear owt, wires come out of the 6 bank retractable switch straight up to each each bank of lights with them sensors . I just don't understand how replacing 1 light on the last run would cause this , unless is has a controller hid somewhere, but then the bank should ov gone off when the light I replaced failed
You need to be talking to your next in line, the people who should be helping you through these situations. You are a trainee and they should be helping you and showing the process of how to resolve the issue. There is no shame in asking for help.
Leeds
Trainee Electrician
Workshop led lighting help
Bowmeat,
westward10,
