no i meant fit the RCD and a MCB in a garage board at the house end. by garage board i meant a din rail CU big enough for a RCD and MCB.
Discuss Workshop supply on a TT in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I may be wrong but if on a stake , you can not use a metal board unless it is shielded in some way around your incoming tails ( not just the point of entry that is , but the enclosure as well ) if the tails were to touch down they would be the wrong side of the earth i think . That is if you have not brought a earth in from the supply side .
Reply to Workshop supply on a TT in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
