Worrying activities! | Page 3 | on ElectriciansForums
Discuss Worrying activities! in the UK Electrical Forum area at ElectriciansForums.net
East Midlands
[ElectriciansForums.net] Worrying activities!
I had a call out today as the customer reported they had no E7 since their electrician replaced the DB.
Looking at the meter I questioned if they ever had E7 as the meter was a single rate 4 wire.
"We did have storage heaters but had them took out so the electrician removed the E7 DB, the associated wiring and the timer clock.
Well that would explain the loss of the E7 then!
Electrician has obviously removed the cut out fuse to do this work and replace the DB with a split load one as no isloator was fitted and the seals were missing..but not authorised to do so no doubt!
Also obviously replaced the load meter tails to the DB as these were new and again seals missing, in fact one of the meter terminal covers screws was missing...again another no no!
The customer also mentioned the same electrician had disconnected the existing TT arrangement and connected the earth to the neutral on a TNCS but the cut out was not labelled as PME....another no no!
Not particularly happy at this point so checked the NIC paperwork for the installation to see a ZE of 0.13ohms recorded so assume correct and within specification.
The cables into the new DB had mostly been extended to reach, I assume they were all tightly and safely crimped before being wrapped in grey insulation tape not heatshrink.
So apart from unauthorised removal of the cut out fuse, unauthorised opening of a whole current meter,theft of a metering time-switch and decidedly dodgy wiring methods it was a great job.
Apologies for the picture quality.
Looking at it, I'd guess the extensions are just singles... possibly the cores from the cable. Had he made an effort to make a decent joint (using non-insulated indent crimps or in-line splices) and then put them in some good quality adhesive lined heatshrink (to provide strain relief), it would be much better. But I'm betting they are standard insulated crimps with no strain relief... no supports or clips on the cables... recipe for disaster and if I were you I'd be advising the client to get the guy back to sort it out before it kills someone.
... and if I were you I'd be advising the client to get the guy back to sort it out before it kills someone.
And that's just the bit we can see... Personally I wouldn't have 'em back. Reminds me of the old days of typing docs - likely to end up with more typos added when fixing the first lot.
main earth looks like its coming from a henley block with the neutral rather than from the heads earth terminal , strange set up
me personally don't like through crimps as difficult to varifie how good the connection is (i much prefer a connection box and some connector strip )
theres mixed colour stickers and rcd notices missing also(unless under the flap ....
so easy to snag others works , but in this case a small child or even my wife could point out a few bad looking stuff
Why is this a good thing? Unless the service fuse is 100A then it is completely unecessary.
You are in a WPD area. I would check on the validity of the authorisation which you think you have, maybe try to get it in writing?
I have it in writing, "Safety,Health and Environment to Industry Standards" "Operation of Cut Out Fuses"
That’s a self-connect meter, there is a separate cover for the outgoing terminals so that an electrician can access them without exposing the incoming terminals. Also there is a single pole isolator under the cover so no need to pull the bullet.
Very true but in that case how did he manage to safely isolate in order to change the 25mm neutral incoming tail to the meter from the Henley block?
not come across that myself, but tbh not looked. I play it safe and dont go prodding where i maybe shouldnt. Can you upload more info on these self connect meters? Not sure i have seen many around this way....
As for the installers joints skills, i would at the very least have used a junction box to tidy the cables and then used either a block or some din connectors on a rail if budget allowed.
I do not believe that was carried out by an NICEIC contractor, you mentioned the cert OP, any chance of uploading a picture of it?
Unfortunately I am not in the position to copy or indeed upload the certificate but having quickly looked through it I can assure you it was NIC and the details entered electronically, my sole interest was the Ze figure given the conversion from TT to PME by the electrician and as previously mentioned this was on the certificate with a value of 0.13 ohms.
Reply to Worrying activities! in the UK Electrical Forum area at ElectriciansForums.net
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
https://sravivarman.com/technical-articles/parallel-operation-of-thyristors/ Series resistor, or bigger series resistor, needed?
