Worst Consumer Unit Pictures Thread! | on ElectriciansForums
Discuss Worst Consumer Unit Pictures Thread! in the UK Electrical Forum area at ElectriciansForums.net
Dan
Staff member
Admin
Mod
Solutions
Staffordshire
Heard about one CU being wallpapered. Wondered what the worst you've seen is, and pictures win prizes.
The one on the left had two wylex fuses hanging in there without the ceramic fuseholder. Thats (on the left) an MEM C/U. And an earth from the MEM in 2.5 T&E!
[ElectriciansForums.net] Worst Consumer Unit Pictures Thread!
Looks like the CU in a Heroine processing plant! What a picture. What IP rating was that again?
Not at those levels of compaction! :)
Westward, I hope you've tendered your multi million pound particulate extraction solution?
Before I took the cover off it was compacted. Was doing an EICR and took ages to find it, maintenance had no idea it was there. If they did any works on the circuits from it they used to knock off its 63A supply breaker. The extraction chamber had been built around it and is probably still the same. No chance of an explosion in there I doubt it contained much oxygen.
Reply to Worst Consumer Unit Pictures Thread! in the UK Electrical Forum area at ElectriciansForums.net
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
2 3
