Would it be ok to replace an earth nut on a ceiling light with a cable / cable and loop? | Page 2 | on ElectriciansForums
Discuss Would it be ok to replace an earth nut on a ceiling light with a cable / cable and loop? in the DIY Electrical Advice area at ElectriciansForums.net
I used to only use 1.5mm cable for lighting, but I've seen the light and now a days I only use 1.0mm. For Wagos, it really needs to be a solid core. You can get 7 strand cable into them but it is a bit of a pain.
What would you recommend?
Reply to Would it be ok to replace an earth nut on a ceiling light with a cable / cable and loop? in the DIY Electrical Advice area at ElectriciansForums.net
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
Looks like the new terminal block has a spare way for those three reds.
