Would like some help with questions about wiring for RV setup on property. | on ElectriciansForums
Discuss Would like some help with questions about wiring for RV setup on property. in the DIY Electrical Advice area at ElectriciansForums.net
boggerdak
Michigan
Hello everyone.
I bought some property in northern Michigan. It has underground electric with a transformer already on the property. I would like to put in 2 RV panels that are 50A each. The county will let me do all of the work myself with the exception of hooking up the meter to the transformer (obviously). The meter has to go by the road. I plan to bury the line in conduit. I have included a drawing for reference. So, the questions:
Does the main panel need to be by the meter or can I put it further into the property?
What would be the proper wire size to run the distances I have shown?
If the RV sub panels are 50A and include a 50A breaker, does the main panel need a 50A breaker, too, or some other size?
Does the layout on my drawing look proper or is there a better way to go about this?
Thanks in advance,
Pete
[ElectriciansForums.net] Would like some help with questions about wiring for RV setup on property.
Hello everyone.
Thanks in advance,
Pete
Yes your panel can be away from the meter but you will need a 50 amp double pole breaker to feed each RV. The size wiring that you will need is # 6
Reply to Would like some help with questions about wiring for RV setup on property. in the DIY Electrical Advice area at ElectriciansForums.net
How about one of these ? No supply needed and has the benefit of having an array of different knocks for all types of moods.
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
