Obviously I don't want my wife to be in danger. I don't want a bath next to a socket either, nor do I want to disregard the regs.
My question was really whether the proposed setup constituted a special location, i.e. a bathroom, considering that the booster bath that is used to bath dogs uses no electricity and can in no way immerse a dog (or anything else for that matter) as it is not enclosed on all sides.
Dogs simply have their hair washed, very much like we might when we go to the barbers.
Sorry, that 1st question was tongue in cheek, I wasn't trying to suggest you were a cowboy!
Just that dogs like to shake themselves dry (unlike humans at hairdressers) and if they are going to be doing that I'd probably be concerned about having sockets within reach.
So special location or not, a physical barrier between "bath" and sockets sounds a good idea. I take it partitioning the shed doesn't appeal?
No need for apologies, I didn't think you were suggesting anything by it.
I was planning to use weatherproof sockets to protect against moisture from 'shaking dogs'.
I can't erect a barrier unfortunately, as it wouldn't be practical; the bath itself is approx 2' 6" wide and the shed is only 8' wide. It would effectively cut the shed in half!
Anyone know a good method of joining two sheds together?
Thanks everyone, you have confirmed what I guess I already knew; the booster bath would classify the shed as a bathroom and at 8x8 it is too small to have sockets in there as well.
There's nothing for it, I'm gonna have to either get another shed for the bath, or replace the existing one.
It's only money I guess...
Thanks again, as always!
At the moment it is on a plug, so I guess it's outside of Part P, however I would want it to be hard wired if we were to do this seriously and have a booster bath installed.
As the shed is in the garden, it is a special location but by adding one of these booster baths, does it then need to be treated as if it was a bathroom rather than just a shed with power?
Think you will find it will come under Part P as unless you apply for change of use it will be still classified as domestic also i would do some checking as local council might be funny about running a business like this from your home.
IEE regs used to say, "In a room with a FIXED bath or shower" Is this still the case? Obviously RCD protection and waterproof fittings (upvc conduit perhaps?)
would be a good idea. As long as you own your home it is no business of the local council until a neighbour makes a complaint! Remember they are our SERVANTS, not our masters!!!
would be a good idea. As long as you own your home it is no business of the local council until a neighbour makes a complaint! Remember they are our SERVANTS, not our masters!!![/QUOTE]
You ever tried telling them that?? lol!! But you are right, it's just that they don't usually quite see it that way, ...Quite the opposite in fact!!! lol!!
You can't export PME mate, there's an embargo on it, but I got a mate who stuffs containers at Harwich, and I could tip him a wink if you want.:single ****:
I thought that you can't export PME as well, although I read somewhere that that only applies if there are extraneous conductive parts in the place you are exporting to, i.e. you cannot extend the equipotential zone outside. My wooden shed has no extraneous conductive parts at all, so in that case shouldn't I be able to export PME if I choose to?
This is a very sore argument, in fact, if you run a sub main to a CU in your shed with a RCD it is really no different to wiring an extension or extra room to your house. This is an argument of interpretation of regulations rather than one of common sense, which we all know is anything but common! When part P came out I was part of a campaign run by an ex government advisor on electrical matters to try and stop its introduction, so as you might guess, I am not registered for part P, nor ever will be, even though I have a C&G Nat diploma in electrical engineering. When it came to wiring my own shed I ran a 2.5mm t/e in conduit to a 2 way mcb CU with an RCD, and at the house end, I fitted a fused spur with a flex and plugged it into a 13 amp socket. In other words, it is a very posh, very safe extension lead, that also is outside the scope of part P ( CUE flamewar)
I can't really see that this has anything to do with Part Pee at all. More to do with electrical theory....
Would this be classed as a special location?
mpspark,
Guitarist,
