Would this cause me to fail my Am2? | on ElectriciansForums
Discuss Would this cause me to fail my Am2? in the UK Electrical Forum area at ElectriciansForums.net
Hatfield
hi everyone ,
I’ve just completed my am2 I think I did fairly well on everything the only thing that’s bugging me is, on my shedual of test results I’m sure I put the wrong size cpc for the c/o detector circuit.
I put the cpc as 1mm however I think it was 1.5 would this one thing cause me to fail?
I very much doubt you would fail if thats all you got incorrect on the the paperwork side of things. I am pretty sure i forgot to tick that i had carried out Phase sequence testing and also pretty sure i put my RCBO down as a 60898 rather than 61009!
Still passed though no problems.
I would say you should be fine. When did you take it? You normally find out if you have passed the same day by email.
Best of luck.
Best of luck.
I finished it yesterday so I’m assuming il get my results on Monday as it’s the weekend, really wish they’d just put me out of my misery now
Where did you take it?
The paperwork has a maximum number of points available so if you only made a small error like this you should be ok IMHO
Reply to Would this cause me to fail my Am2? in the UK Electrical Forum area at ElectriciansForums.net
The video's are an accompaniment to the Book and referenced throughout.
When I did my AM2, I had it drummed into me that I had to follow Guidance Note 3 carefully. So, did you follow the guidance in GN3 for checking...
