Would you energise a modified circuit without RCD protection | Page 2 | on ElectriciansForums
Discuss Would you energise a modified circuit without RCD protection in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Pretty much what the title is.
Asked to do a job, don't have time to do the board change but could make the changes to the kitchen socket circuit...
So testing of sockets would be done, but no RCD protection (very old board so no upgrade path) until CU is changed in Jan
Tin hat on!
Pop corn at the ready.
I took on a rewire recently where the original spark had completed the kitchen and energised it with no RCD protection. I was asked for my thoughts and honestly replied that it didn't comply with the current regulations.
I rewired the property but energised circuits, before the new board was mounted, through a temp board equipped with 30mA RCDs that came off the Henley blocks. I kept a note of the test results for these circuits and transferred the circuits when the new board was mounted.
It was the safest and most compliant way I could think of. The new CU needed to occupy the space that the original one did so I could not have them running side by side.
I would say always protect your butt, fit a temp' rcd that way in the unlikely event of anything bad happening then your covered and your insurance isn't voided if that comes into play, it's fine saying the job isn't complete until the cert# is issued but you are still responsible for any work done, the safety of that work and that is complies to current regulations ... yes I can somewhat agree with the fact we all wired non RCD's sockets for decades with little issue but you could argue the same about wearing seatbelts.. they are just an inconvenience until you need them to save your life. :)
Reply to Would you energise a modified circuit without RCD protection in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
