wylex 45A mcb? | on ElectriciansForums
Discuss wylex 45A mcb? in the Australia area at ElectriciansForums.net
B
billy-w
Hi,does any one know if wylex do a 45A mcb, i have a 10.5kw shower to fit next week, the cu is 17th edition wylex so quite new, i can't for the life of me find one. Failing that is there another make that i could use? :confused: Cheers.
50 Amp Wylex MCBNSB50 [ElectriciansForums.net] wylex 45A mcb? NSB mcb's designs are subject to change
MCB's may differ slightly on new purchases and from existing mcb's
but are all interchangeable
MCB terminal capacity, </B>25 mm on all mcb's
Wylex-NSB MCB ( Type B )
Rated 50 Amps
General Domestic Consumer Unit use
Wylex NSB MCB's detect overcurrents due to both overload and fault currents.
The MCB will operate and interrupt the supply to prevent damage to the installation.
  • Wylex NSB Domestic MCBs have a short circuit breaking capacity of 6000A (M6).
  • The current carrying capacity of the cable should always exceed the current rating of the MCB to prevent damage.
  • The operating dolly may be locked in either the ON or OFF position without affecting the ability of the trip mechanism to operate.
  • When in the off position, a contact gap of 4 mm is achieved. Wylex NSB MCBs may therefore be used as single pole isolating switches where appropriate.
I would fit a 40a one. a B type MCB will run at 5 times rated current for a lot longer than it takes to have a shower. I Have fit loads with no problems. Nothing wrong with 50, its just my opinion.
Cheers..........Howard:)
Reply to wylex 45A mcb? in the Australia area at ElectriciansForums.net
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
