wylex board | on ElectriciansForums
Discuss wylex board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Nice timing lads, I've just been doing a PIR on an installation that is controlled by a 4 way white Wylex rewireable fuse board dating back to the 60s or 70s. I couldn't find a hint of the BS No or rating for the main switch.
I believe that it is BS 5486
Nope, that is the standard for the distribution board, not the main switch. It would still be BS5419. Just as a BS EN 60439 is the standard for todays enclosures and consumer units, and the main switch is a BS EN 60947-3.
Reply to wylex board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, I hope you are well, a friend has lost power and it's the main switch that has failed I've got a bunch of different brands in the garage...
Not uncommon over here for that mistake to still be made with twin brown. Seen a few circuits ripped out when 1.5 3C&E was lifted instead of 2.5 T&E.
nicebutdim
N
