wylex db | Page 2 | on ElectriciansForums
Discuss wylex db in the UK Electrical Forum area at ElectriciansForums.net
I
iamelectric
anyone still fitting wylex consumer units , have they sorted out their problems with the mcbs melting , is it worth still using them?
good thing with proteus is you can fit the CU then worry about the knock outs, nothing like fitting the board then realising you need to try knock a bigger hole,, but not too big! used to fit crabtree starbreaker all the time, nice layout but as above, gota get the knock outs right before you fit
Still can't see the appeal of wylex (and have never have made anything good imo), ugly, unreliable grey box on the wall. Also lost my temper many times with trying to get the knock outs out and another cable in when adding circuits to them.
Don't mind MK (ok the cover is a pig to get on) but normally using contactum (or the British General version) still
Reply to wylex db in the UK Electrical Forum area at ElectriciansForums.net
Ah my mistake - apologies. I have something more or less like this wylex unit and the flappy plastic cover has got a broken pin so won't stay one...
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
