Hello everyone
In my garage, I have an old Wylex Fusebox (see attached) containing a 5 and 15amp fuse. Both of them have now blown which means that they need replacing. From reading around the internet, I understand that I can purchase some Wylex MCB's. I've looked on Screwfix and there's a couple I can get. I'm a new homeowner so need a second opinion before I purchase anything.
https://www.screwfix.com/c/electrical-lighting/mcbs/cat7230022?brand=wylex
Can you point me in the direction of which specific ones I need? Many thanks
Hello everyone
Repair the ruptured fuse with appropriate fuse wire
You need a blue and a white one.
16A and 6A.
With a bit of luck, the MCBs will plug straight in.
If not, you’ll have to change the bases.
Save yourself a few quid and have a look on eBay, plenty used ones at a good price, some brand new and still cheaper than screwfix.
Curious as to why both his fuses have blown. I think rather than just replace the wire (or even retrofit MCBs) I would be getting it checked out by a sparky.
simple.bulb blew out, taking the 5A fuse out. OP plugged in a 10kW floodlight to see to fix and blew the 15A.
Bradford
Wylex fuse required in garage
Ali Ahmed,
freddo,
