Wylex Type D MCB help.
M
mattcos1972
Hi all,
Thanks in advance for your help with this issue.
I am having a bit of trouble finding a type D wylex MCB to fit in a screw fixed board.
As far as I can make out wylex only make a type D breaker to fit din rail boards but was this always the case? Does such an item exist? I note that the latest wylex PS range of type D breakers will not entertain the screw fix bus bar but are the type D NS or NH breakers out there hiding from me??
If so I need 2 x 32 amp!!
Cheers again for any help!
Just an idea...failing that could I rip out the screw fixed bus bar and replace with din rails?? Just a thought. Let me know what you reckon???
Matt
Hi all,
Matt
Not much help but I don't think I've ever seen a Wylex type D other than din mounted.
The Wylex technical number is here, maybe they will shed some light?:
Telephone: 01543 438320
I'll go an raid our redundant mcb box, I know we have D20 Hagers but you never know
I have and we have'nt
