Y plan with 2 port twisting my melons man
with the overheat in-between these of course[/QUOTE
Do you mean the cylinder stat in between as if it fails the two port will not open and thus no hot water, safety cut off
No I mean safety overheat its a secondary stat basically if the cylinder stat fail this will then trip on over heat shutting the valve stopping the cylinder becoming a bomb
This is to stop if for instance the cylinder stat got jammed to call the over heat would trip shutting the valve if that makes sense lol
Update- been this morning, added HW off from programmer to wiring centre ! All works fine now with dual stat shutting off 2 port when up to temperature...many thanks to Justin and Richard
