T
TheoJones
But there's a twist that makes it interesting, honest
just moved house, and I have a small outhouse roughly 5 metres from the main building, then the garage a further 30 metres on beyond that (35m as the cable goes, there's a duct involved to the garage).
power to the wee outhouse is shonky as get out just now, and I am replacing it, garage has no power just now - thinking I should use this as a good opportunity to do things right for the garage too.
My plan is...
Add a 40A MCB to the house CU, and run over 6mm 3-core SWA to the outhouse, tying the outhouse into the CU's Earth.
Have a small 2-way there, with a 16A RCBO for a couple of sockets (only expecting a freezer in there, possibly plugging a lawnmower in) and a 6A RCBO for lighting (never in a million years going to use more than half an amp, but hey ho...)
Then, bus the Live and Neutral onto a 6mm 2-core SWA onwards to the Garage to another 2-way, garage is a brick built affair, no external metal, but has water (copper back to the house). Planning to use an earth rod there.
Again, 6A RCBO for lighting circuit and a 32A RCBO protected ring on 2.5mm T&E
The thinking is:
Happy that there's spare capacity for a 40A MCB, because the house has a 100A supply, and we have put in gas central heating and gas hob, replacing storage heaters and a leccy hob.
Keeping the house earth for the outhouse as it's only 5 metres over nice fat conductors, and an earth rod would be a PITA where the outhouse is.
Using 6mm SWA where 4 would probably be okay just to over-engineer it a bit and get some margin in there.
No RCD protection in the main CU so you don't get into a situation with the thing tripped inside the house, and unable to reset it in the garage/outhouse, so protection at the edges instead.
I'm reasonably confident that this is okay, but this isn't my day job, so I'm cautious enough to want to get a proper set of eyes on this rather than kill myself/the wife/the neighbour's dog.
Any gotchas that I have missed?
Tj.
My plan is...
The thinking is:
Tj.
