sjm
Customer wants to change storage heaters for Rointe panel heaters.
The existing storeage heaters are feed from consumer unit with 100ma RCD, the system is TT earth.
My question is do you guys think I can change the supply for the cu from off peak and swap the heaters, but not worry about changing the RCD to 30ma. I will not be adding any cables that will be burried in walls.
Thanks in advance.
Steve
Thanks in advance.
Steve
