Zanussi electrical oven started tripping the RCD | on ElectriciansForums
Guest viewing is limited
Discuss Zanussi electrical oven started tripping the RCD in the DIY Electrical Advice area at ElectriciansForums.net
Surrey
Hi All,
I am new here.
I searched the forum regarding this issue and most professional advice was that the heating element should be at fault.
I am a DIY person and I would not have a problem replacing it myself, only that a new heating element costs £45 on Zanussi.co.uk and I would not want to pay for it if thats not the issue.
It started tripping 4 days ago, sometimes starts working on fan or grill+fan for a bit -(more or less 1 min) then trips. Other times trips the circuit straight away.
1 year ago I might have sprayed oven cleaner on the element while cleaning but if that would cause something I assumed it should be sooner rather than later.
I opened the back of the oven intending to remove the heating element, so I noticed some burns to some of the wires (pictures attached) - the wall connection looks ok.
Could somebody kindly advise if it’s worth to replace the heating element or maybe is a situation where I need to look for another oven?
[ElectriciansForums.net] Zanussi electrical oven started tripping the RCD
Reply to Zanussi electrical oven started tripping the RCD in the DIY Electrical Advice area at ElectriciansForums.net
Glad you got it sorted.
Oh I get that for sure. Here it's not the problem though. The oven is in very good condition, and works well, just the heating element is warped...
