Ze 8.34 | Page 2 | on ElectriciansForums
Discuss Ze 8.34 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ì you in london theyll probably charge you heavily for to fix it or tell you to supply your own earth rod.
If an earthing facility is supplied it is the legal responsibility of the supplier to maintain it so there will be no charge for this work.
On a lighter note, I had a Ze of 0.01 yesterday and that's testing it properly!!!
Out of interest, ...How did you test it properly?? I ask, because your standard MFT's and separate ELI testers just don't have the resolution required to give anywhere near accurate readings at this sort of level....
Use the Jedi force, That reads down to 0.000000000000000001 ohms :)
Reply to Ze 8.34 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
