Ze on a SWA | on ElectriciansForums
Discuss Ze on a SWA in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nicsin02
Hi guys, i am testing a 3-phase D/B tomorrow and its supply is only a 4-core cable so its earth comes from the Gland-frying pand and then a flying lead to the earth bar, normally doing domestic property i would disconnect earth for Ze ensuring no parralell paths, what would be the norm on this occasion? thanks guys
same procedure but measure o each of the phases. reconnect earthing conductor for PFC reading. ensure installation is isolated before dissing earth. if it's a sub-board, the EFLI is noted as Zdb
just remove any bonding cables.... and clip on to rail.... f its a PIR put it down as a limitation...!
if you take gland off and damage it putting it back on or damage teh strands it will be hell to fix..!
in that case, i would disconnect any bonding conductors and the fly lead. i might get shot down , but i would prefer that to the possible risk of compromising the integrity of the glanding by disconnecting . apart from the risk of having 3 live phases flopping about unglanded.
- - - Updated - - -
beaten to it by torpedo fingers. GRRRR>
must be getting old. bloody heart attack slowed me down. making a good recovery now i'm back on a few beers, though.
If this is a swa feed would this mean it is a sub-board or a feed from a switched fuse as in both cases its not a Ze but a Zdb (Zs).
Its not normal to have a swa feed in the usual sense of a supply without it going through another device.
yeah its a sub mains fed from another board, i know its a Zdb but would still have to fill it in the Ze section for the new sub board or am i wrong lol?
Reply to Ze on a SWA in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sounds more positive.
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
