Ze/PFC testing | on ElectriciansForums
Discuss Ze/PFC testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
greeny
Hi All,
When I carry out a Ze test , I test at the CU input with all load circuits isolated, ie with the main switch off.
I disconnect the main earth from the cu and attach my earth test lead lead to it. That way I am looking backward down the supply (as a supply characteristic.)
When doing a PFC, I reconnect the main earth but should the main CU switch also be off.
Reply to Ze/PFC testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
On the minor works in the brown book it has Zdb
Hi Dave thanks for the info I revisited the premises to change a cooker switch and redone the test from the MET with MET disconnected from DB...
