ze testing with a fluke multifunction tester | Page 2 | on ElectriciansForums
Discuss ze testing with a fluke multifunction tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
cheers mate,
i have my 2391 written on thursday 10th and practical assessment on the 15th of june so needed to make sure as i have a megger 1552 and for practical will be using a fluke and i am not used to it thanks
surely they should let you use your own meter as long as it calibrated, have you asked?
my megger i got last august i did another course for 2382,2377,2393,and part p. I got the megger at the end of the course as part of the cost of the course i have not used it as i am not working at minute just studying since feb for this 2391 as i am a carer for my mrs. the megger has never been used the calibration certificate is dated last jan 2009 i asked megger and they said as i havent used it and its guaranteed for 3 years the calibration only starts from the date of commission ie when i start to use it so still calibrated according to them.
but i dont know if the college would let me use it still has all wrapping around it not used on any testing
as i want to hopefully pass the 2391 then start to set up for myself to be able to work from home so dont kow mate my written on thursday practical following tuesday just av to give it a go and hope for best if not take a resit i paid extra for a optional day £85 to practice on athree phase and single phase but there was 4 of us doing all the required tests between us with one meter bit s??? really as we didnt get to do all the tests
If it is a megger 1552 there is a quick start guide in there with it that explains all the tests pretty well. TBH i would go with your own meter as you can be practising with it on your house and get really familiar with it.
cheers mate i am going to ask them can i use it we will see
when i do the assessments do i have to carry out safe isolation on the 1st and second assesments even though they are dead
also for the 2nd test insulation resistance do i test it as a whole installation and when i locate say a fault between l-n start turning breakers of till the insulation resistance rises then i will know which circuit the fault is on cheers mate
always carry out safe isolation procedure
Yep much quicker to do it this way :)
cheers mate,
so for first, second and fourth assessment perform safe isolation inc lock off
do i need to do it for the 3rd assessment the earth fault loop test to check zs against gn3 do i need to do it for that or should i just switch off then conect plug in lead of the tester set to loop range switch on carry out test switch off disconnect check results against gn3 max measured tables
Reply to ze testing with a fluke multifunction tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Hi all, The electrical network in my house (Antwerp, BE) is quite old and consists of two phases of about 140 volts. This gives me approximately...
