Yes mate. If the 2nd, 3rd 4th etc decimal place is not required, dont need to use it or it would become 0.800000 or 0.8 X 10 to the power of minus 6 :wink: (level 3 maths, you will see)
^^ that is correct isn't it gents? Been a long time since writing this form of equation and it does not look right?
Yes you do, the number of decimal places displayed is significant in any calculation as it defines the accuracy of the end result. There's no point using a good quality tester which reads to 2dp then only recording the result to 1dp, you might as well use a less accurate tester.
Oh and 0.8 x 10 to the -6 would be 0.000008 ;)
(Or it might even be 0.00000008, thanks Mr styrofoam)
...This is why that Mars lander bounced off in to the yonder....
"By calculation", 0.8 x 0.320 = 0.256 not 0.3
By restraint of scale,rounding down etc,yes,but NOT by calculation,which by its' description,is definitive.
0.8 x 10 to the -6 is 0.0000008 or 8 to the -7 , the power of -6 being a millionth,micro or multiple of 0.000001.
...And,as my maths teacher was inclined to ask,after a grueling,set of calcs,"We know friction makes heat?...and heat boils water?...So how long will it take a donkey to ---- a bucket of water,so we can have a cup of tea?" :icon12:
about 15 minutes if the donkey's on ------,
Ok I should have said 0.8ohms x 0.320 =0.256
In any scientific calculation an answer cannot be more accurate than the least accurate input value.
Indeed, but you shouldn't make any assumptions about accuracy based only on the number of decimal places or significant figures used.
See my post here: http://www.electriciansforums.co.uk...0424-three-phase-calculation.html#post1079853
My multimeter shows values to 4 significant figures. Can I assume that it's accurate to plus/minus half of the final digit? No! But I still might write down the value I see on the display.
Here's another (silly) example: Would a shop selling something for £1.49 accept a "one pound" coin (0 decimal places), since it's not labelled as a "£1.00" coin?
Wirral
Ze Values? HELP
Thread Tags
Underpaid,
newtothis,
