Hi all,
just a quick question, i'm currently learning how to test different installs, I have been testing houses and obviously it's easy to get to the service head and determine what earthing arrangement etc and also taking Ze from the consumer unit ect, but when testing Ze in an environment where you cant get to the service head do you still record Ze from the consumer unit or will that be recorded as Zs? also if there is a KMF switch should you take your Ze reading from that instead of the consumer unit?
cheers
Deano
cheers
Deano
