Zone 2 lights and fan isolator switch | Page 2 | on ElectriciansForums
Discuss Zone 2 lights and fan isolator switch in the UK Electrical Forum area at ElectriciansForums.net
west midlands
Hi .can someone let me know if I can install a battery operated smoke alarm and also.carbon monoxide alarm.for a rental accomodation ? Would this be satisfactory ( pass a EICR )
Secondly if i have fan isolators on zone 2 in a bathroom and ensuite so they need to be waterproof
Also if the lights in the bathroom.and ensuite are in zone 2 , do they need to be waterproof . I have been they need to be changed as they have a metallic base and they need to be plastic instead
In that case neither the lights or the isolator should attract a C2 on an EICR.
Smoke alarms are required, as is a CO alarm if there is a possible source of CO present, but are nothing to do with an EICR, other than their supply wires and connections if they are mains powered.
The type required is down to the local authority and fire officer.
Thank you for the feedback Brian
Reply to Zone 2 lights and fan isolator switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
