Zone 2 Shower - Permanent Fixed Partition | on ElectriciansForums
Discuss Zone 2 Shower - Permanent Fixed Partition in the UK Electrical Forum area at ElectriciansForums.net
Does the non opening side of a typical perspex shower cubicle represent a "permanent fixed partition"?
Having a "discussion" with a colleague regarding the "plan" diagram p.89 OSG (yellow). Discussion centres around whether the PFP needs to be a wall or just the standard perspex cubicle side.
This relating to positioning of a shower switch right next to the cubicle where the non opening side junctions the bathroom wall - below 2.25m....
so Zone 2 or not depends on definition of "permanent fixed partition".
You will need to "locations Containing a Bath or Shower" I would say No a perspex cubicle side is not a permanent fixed partition (in my opinion)
Don't know sounds like he is having a discussion with a Mate
Still need to know the context of why they were discussing it ...
See loads of stuff every week that isn't ideal .............. but you can't go around making customers pay for things that aren't relevant to what you are working on ............ but you can comment on a Cert or Invoice!
Apologies, yes it's an eicr on sale of house, debate with colleague as I intend to recommend relocation, he says not required....hence interested in the views of the wise heads that frequent the forum.
I think its in the area of "ambiguity" - the specialist subject with the muppets that write BS 7671
BYB P209 d) - what is the definition of a permanent fixed partition? is it a wall or a fixed piece of glass?
You could C3 it!
The location and zones are bounded by walls, fixed partitions, ceiling and floor.
The fact that the Regulations list walls and fixed partitions, suggests that a fixed portion does not have to be a wall.
Interesting reply, however it's a bit like Amd 3 saying that a 'non combustible' material needs to be used for CU's. They then give the example as being metal, which in fact is almost the only viable option to comply.
I wouldn't have thought a piece of perspex attached to a shower would be classed as a permanant fixed partion as it could be unscrewed and moved.
Actually I think I've misinterpreted your post a bit. i thought you'd written 'The regulations lists walls as fixed partitions'.
You could C3 it!
Or you could FI it as you need the next months to discuss with the building authorities what they actually mean by a permanant fixed partition. :)
Reply to Zone 2 Shower - Permanent Fixed Partition in the UK Electrical Forum area at ElectriciansForums.net
