Zs again | Page 2 | on ElectriciansForums
Discuss Zs again in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yet you find it easy to connect the probes to the same two points to do the R1 + R2 ............. Is this because they're live?:D
And this after 'faffing' about in the CU disconnecting circuits and tightening up connector blocks. :p
The probes on my continuity tester are much finer than the probes on my earth loop lead which are bulky and sometimes difficult to engage in the small terminals often found in luminaires....There are only two probes to connect,not three,I'm going to do an R1R2 whatever,(is running out an R2 lead any less hassle than linking in the DB?)....and chances are even if I do manage to connect the earth loop probes the ***** type B mcb will pop out....:mad:
And this after 'faffing' about in the CU disconnecting circuits and tightening up connector blocks. :p[/QUOTE]
I keep a few Wago reusable push fit connectors in the testing kit. How much of a pain in the wrist are screw don connector blocks?
You could always link out L & CPC at the luminaire and test Zs at the CU - no more dangerous than testing PFC, Ze or RCD :)
Reply to Zs again in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
For a new circuit or alteration the dead tests should be done first to ensure it is safe to energise.
I am living in the north of Thailand outside of the big city. That means in the rainy season we have multiple times per week power outages...
