Zs high at db lower in field. | Page 2 | on ElectriciansForums
Discuss Zs high at db lower in field. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
How much higher is it getting then??
What equipment have you got in the circuits then mate?? lots of electronic equipment could do it
It started at around 235, varied in between and then ended up nearer 245 roughly at the furthest point.
There was very little load on the system during the day.
Even when it is loaded, its only lighting and heating.
Done many a PIR, although not like this, and never had this prob before.
Could be a capacitor in a light fitting breaking down and shunting more voltage into the system than it should.
I got brain fog now:(
Reply to Zs high at db lower in field. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
wouldn't surprise me if we adopt this sooner or later...
