Zs on lights spur of ring | on ElectriciansForums
Discuss Zs on lights spur of ring in the Australia area at ElectriciansForums.net
rick
Bedfordshire
At a property today I found that several lights have been taken as a spur of a ring main. At the end of the spur I get 1.33 Zs which is too high as it's on a 32A B MCB and should be lower than 1.16.
If I convert this to a fused 3A spur with FCU, can I used the 3A fuse to calculate the max Zs allowed? (which would be OK if so)
Reply to Zs on lights spur of ring in the Australia area at ElectriciansForums.net
hI Gent's. I I can explain this spur line briefly, maybe someone can help me? Everything is Spur, no rings. Inside of the house and main fuse...
Haha yes, it is. Must be a northern expression. Have a Google 😂
